I have a 1995 Ocean Pro 150. The fuel pump has died and my mechanic tells me it is an electric pump.
Now my understanding is that these engines came with a VRO fuel pump. Mine does not do VRO and I add oil to the gas tank. I assumed a previous owner had modified it to remove the VRO as I understand they could be unreliable.
My mechanic says that the electric pump is original. Is this possible? Did they produce this engine with an electric fuel pump and no VRO? The engine ID card with the model number is illegible, so if it was an option, I couldn't tell from the model number...
Everything I have read says that electric fuel pumps are a bad idea. Would you recommend returning to the VRO pump, but with the oil function disabled?
Thanks
Huw
Thanks
Huw
