1995 mercury 200 hp offshore 2.5L stalling or bogging
waltdiggity
motor will idle in gear fine for 15 min then rpms drop and motor dies. motor will run high rpms for a while then rpms may drop down gradually till it stalls. it will run wide open then when you back off throttle rpms drop and gradually dies. carbs have been done fuel pump diaphrams are new, no leaks in fuel lines or connectors. ive run it on external fuel tank, still no luck. PLEASE HELP. IT DOESNT MAKE A DIFFERENCE IF YOU PUSH THE CHOKE WHEN ITS DYING EITHER.
gss036
Re: 1995 mercury 200 hp offshore 2.5L stalling or bogging
What if you pump the primer bulb? Does that help, if so may be time replace it. Does the primer bulb go flat?
Try blowing air back into the fuel tank to see if you have junk on the pick up tube. So will have a screen , others not. What about the anti siphon fitting on the fuel tank? Does it work?
