1995 mercruiser 3.0lx compression trouble s/n 371961
thmlrmg
ok to start with i sucked a screw in through the carb and in went all the way down to the #4 cylinder and destroyed the piston. Before anything I checked compression on all the cylinders and there was nothing. I removed the motor and completely rebuilt the motor with new pistons and everything. The head was bench tested ok and milled down flat. Now with the motor back in the boat and all new parts i still have no compression? With the #1 cylinder push rods disconnected to close both valves i have 50 psi of compression? Any help would be appreciated. thanks
Alumarine
Re: 1995 mercruiser 3.0lx compression trouble s/n 371961
Are you using the starter to turn the engine over when checking the compression?
thmlrmg
yeah, everything is in the boat and hooked up. I have a battery charger/starter hooked to the battery to make sure i have enough cranking amps.
Alumarine
I think your best bet is to do a leak down test to isolate the problem.
thmlrmg
will do, i will tomorrow until then any other input would be greatly appreciated
Don S
Are you sure you have the valves adjusted correctly?
If, when you started adjusting and wasn't on #1 TDC, then you won't get any compression.
PS, with both valves closed you won't get the proper compression either because you can't get air into the engine to comrpess.
muc
"Retired" Association of Marine Technicians...
Sometimes it is hard to tell when you have reached zero lash.
I find it helps to spin the push rod with my fingers and when it gets hard to spin that is zero lash --- I think this is easier to feel than the up and down movement.
Good luck Muc
