1995 MARINER TACH nightmare!
8000+
Hi guys, you are my last resort!
I just purchased new TELEFLEX gauges and the first problem I have with them is not knowing which PULSE/CYCl setting on the back side I should use!
Please help me out. I have the manual but nothing like that is mentioned....
The engine is 2 stroke, 1995, 90HP one.
The TACH is the same as this one:
http://www.downloadingfiles.co.uk/teleflexfiles/gauges/page342.pdf
Latter problem is that I don`t know where can I mount the sender for water T and OIL pressure!
THX in advance!
sschefer
Re: 1995 MARINER TACH nightmare!
THX in advance!
Check http://www.mercurymarine.com FAQ's they have a guide that will list the correct setting for you Tach.
The temp gauge could hook up to the temp sensor I guess.
The oil pressure gauge is going to be a real problem since to the best of my knowledge the oil is mixed with the fuel and there is no oil in the crankcase or traditional oil pump that you can get a pressure reading from.
saumon
6p
I hope you mean water temp and water pressure cause there's no oil pressure on thoses.
Fitting is above the top spark plug hole (brass with hex head, that you replace by an elbow (temp OR pressure) or a tee (temp AND pressure))
Hope this help.
8000+
THX guys! You ROCK!
Regards from Europe,
Frenky
