1995 Mariner 60HP outboard.
Is it possible to remove the lower leg and leave the power head attached?
I have a cooling system leak at the top of the leg and am trying to avoid lifting the whole power head off. There is a 2" spacer between the power head and the leg that the steering is attached to. I would like to remove below the spacer/steering connection.
I have removed the lower gear case and put water via a hose up the cooling tube. Most of it comes flowing back down the leg. None of it is coming out inside the cowl so I don't think it is the upper gasket.
