1995 Mariner 175 EFI no power when in gear
arrowhead_40
I bought a 1995 Skeeter bass boat with a Mariner 175 EFI motor. It had not been run in over a year. It was not getting fuel, so I cleaned the VST and replaced the fuel filter. Finally got it to run. Water pump not peeing, so replaced water pump, impeller, and gaskets. Still not peeing very well. Motor bogs down and loses power when placed in gear. The motor will rev rpm’s when in neutral. Suggestions?
Dukedog
here's a list of a few things......
compression
dirty/non firin' injectors
mech fuel pump
fuel lines
ecu
'lectric fuel pump/regulator
lectrics.. trigger, stator, switch boxes
spark plugs/wires
idle stabilizer module
linc n sync... all justa start!
water pump needs ta include base and housing.. poppet, stats.
