preston334
- Nov 9, 2014
- 4
I have a 95 Mariner 115hp that ran out oil. (No, the oil sensor didn't go off.) I cleaned out oil tank and lines, replaced plugs and fuel filter as a precaution. As u can imagine, it ran a little rough so I adjusted carbs to smooth it out. The motor doesn't have a whole lot of interest in going into gear unless it's given a little extra throttle. Further investigation found that I've got 120 compression on cylinders 1, 3, and 4. Cylinder 2 has zero compression. Is this more than likely an engine rebuild? If so, would this engine be worth it? Or should I just scrap it and get another?
