1995 Kawasaki 750 SS jet ski
vixx
This jet ski has fire but will not start. The battery is good, all lights light up. It started when we bought it. Drove 10 miles home with it and haven't got it started yet. Any ideas?
vixx
well got it started but it will only start if I spray the carbs with a little starting fluid. Any suggestions for a fix?
bently
Bad/weak fuel pump or bad fuel lines. I would replace fuel lines and rebuild fuel pump. How is compression?
SflSurfRider
If it has dual keihen carbs, they typically have to be choked. I run mine at one click away from wide open.
