1995 Johnson30hp
jmiskovs
Hello,
I'm trying to remove the lower unit from my engine to replace the water pump and impeller. That lower unit will not drop down after all the bolts are removed. Any suggeststions, tricks? Thank you.
Honorary Supreme Mariner
Followed these steps ?--------Removed water intake screens.-----------Scrape paint off the upper shift rod.------Undo coupling nuts.------Slide the UPPER nut up the rod.-------Now remove the wee black plastic keeper.------------Lower unit now comes off.
jmiskovs
Yup, that was it. Now, it's about a half inch shy of going back together. Any ideas for that? Thanks so much.
AlTn
turn either the flywheel or propshaft while trying to push the lower unit and exhaust housing together.You will be trying to align the splines on the driveshaft so it will slip back into the crankshaft
