1995 Johnson Quick Strike hose routing
rcb130
Hello,
I am in need of a hose routing diagram for all the hoses on this motor with the exception of the recirculation lines. I have the manual but it does not show what I need. If need be, I can post pictures of the connections I need or am not sure of.
Thanks in advance
RCB130
rcb130
Re: 1995 Johnson Quick Strike hose routing
Guys, I really really could use some help on this one.
RCB130
CatTwentyTwo
If this is a 150 or 175hp motor I could try and compare it to my 94 Ocean Runner if you like. Put up a couple of pictures of the connections you're not sure of and I will see if I can help.
Faztbullet
You need routing on vapor separator??
rcb130
genes motor 011.jpggenes motor 012.jpggenes motor 013.jpggenes motor 014.jpgCat Twenty Two, Faztbullet,
Thanks for responding, I will try to post pictures. Part of the routing is the vapor pump.
CatTwentyTwo
View attachment 173403View attachment 173404View attachment 173405View attachment 173407Cat Twenty Two, Faztbullet,
Are you intentionally trying to make me dizzy?:)
I believe your first picture is for the lower bearing vent, that's where the hose from the starboard balance tube connects to (your picture 3?).
One of the hoses off the tee goes to the fitting for the upper bearing vent in the middle of the block right below the flywheel. The other hose just gets pushed into a rubber grommet on the air box.
It's a little hard to see here but the hose from the port balance tube plugs on to the nipple at the bottom left of the air box. The rubber grommet for that other hose that comes off the tee is just above the top right carb opening.
boobie
What manual do you have ??
boobie
From all the OEM factory service manuals I've seen the hose routings are in them.
CatTwentyTwo
Except for that tee and the hose that goes to the upper bearing vent. I've always wondered about it because OMC doesn't show it in their hose routing diagram in my manual.
