Carolina Country Boy
Thread starter- Joined
- Apr 18, 2020
- 16
Hello everyone, I'm hoping to get some help on a couple of issues I'm having with my '95 Johnson Fast Strike. First issue is that it's leaking fuel from the weep holes located on the side of the bowl of the carburetor. I seen an older post with somebody having the same problem. It seems that this is common with these motors and the fix was to clean the weep hole (looks like it has a bb inside of it) and seal it with epoxy. Is this the fix to this problem? Next issue, having problems with the vacuum switch alarm. I've checked all of the fuel lines, primer bulb and anti-siphoning valve which my tank doesn't have.I could not find any fuel flow restrictions. The motor runs with plenty of power with no problems. I have noticed that when the motor is first started on a cool morning the alarm instantly comes on but after the motor warms up it stops. Thanks in advance with any ideas that may help.
