1995 johnson fast strike 175
Staylor126
Misses badly above 3500 rpm like it's on the Rev limiter runs good all day as long as you don't get above that 3500 rpm range .ZHELP
boobie
Do a cylinder drop test on it and see if you can narrow it down to any cylinder/s.
Staylor126
Have tried that makes no difference still misses above the 3500 rpm range. Have tried new powerpack, voltage regulator ,stator,optical sensor ,battery,plugs ,took fuel sample all OK and no change. Started after original power pack went bad and was replaced with a new XD I powerpack
Rustywrench
Not familiar with XD I power pack, but aware someone new may be on the market? You must use QL78YC Champion spark plugs only! The OIS ignition system will not tolerate other types. Unless this new pack has done something to change that? Just a reminder.
Rustywrench
Dang auto correct! Just another stab. Did you do a pack kit, pack, sensor, & plug wires (gray wires)? Does your motor have the old black plug wires by any chance? Outside of a bad pack (not unheard of) I think you are going to have to start looking at fuel. Can you run it on the trailer & do a drop cylinder test? If you have an old aluminum prop cut the tips of the blades. Makes a good cheap test wheel. Trim the tips till you get 5000 RPM at WOT on the trailer. (Or whatever you can get for now?)
bob johnson
can you elaborate or show a picture of the Modified TEST WHEEL-PROP? thanks bob
Rustywrench
I have gotten rid of all my late model stuff. (Retired). Now I am into antique outboards. Just measure out from the hub & use a saws all to cut the tips of the blades off shorter. Nothing fancy! The key is to not cut too much off until you get a feel for how much it takes to get the RPM right. Depends on what prop (pitch) you use to begin with? Usually a couple of inches tops. Sneak up on it as it's hard to put the metal back on the prop, HA!
Staylor126
It has the gray wires and have tried pulling one plug wire off at a time and ran it up to that 3500 rpm range still runs like it's hitting on the Rev limiter on the trailer you can only load it to around 3300 wot never misses now have ordered an oem powerpack don't what else to try .
