1995 johnson 90hp v4 ocean runner carb leak need help
yeygo
Carburetor is leaking from ..... actually ill post a pick of location, i just did a whole gasket kit rebuild on it
Heywood2
My Johnson ocean runner has leaking carbs as well.
I spoke to one of the local shops today about having them rebuilt and he informed me that all of the float bowls would need to be replaced.Seems the small epoxied plug of the sid of the float bowl begins leaking as they get old.
So i checked and sure enough,they are leaking right where he said they would be.
hope this helps
yeygo
Thanks heywood2.... im going to have to open her up again 😩🤷🏽‍♂️🎣
Chris1956
Honorary Supreme Mariner
If it is leaking into the carb throat, perhaps the float level is set too high.
