1995 Johnson 8hp
Supersportster
Hey...
I purchased this motor to use as a trolling motor. It starts first pull with the choke out, it shifts into gear and runs great mid and full throttle.
The issue I am having is that when you I try to run it slow, it runs nicely for about 30 seconds, then just dies out. I have adjusted the idle screw on the side of the carb, the manual says 3 turns out, the motor seems to like 3 turns and a little bit more.
I have good compression on both cylinders 115.
What else can i try? Should I rebuild the carb? I have the manual, Should I do the procedure for the link and sync?
Thanks for any advice!
