water proof wick
Thread starter- Joined
- Jul 17, 2015
- 12
this is my first post on iboats . I recently purchased a 1995 alumacraft 190 trophy in almost mint condition with the exception of poor running quality , started fine within seconds every time but no power had to run at idle back to the launch . With the help of iboats forum I managed to remove the carbs ,soak , clean , replace jets , and blow compressed air through every hole I found , I went threw this process slow to be sure it was done properly . Both the floats worked and were level from my observation . I replaced the plugs set gap at 35 . replaced fuel line with new claps . The engine looks untouched with the exception of the fuel pump gaskit (between the pump and power head ) missing , I found it under the carbs , so I put that back in . The boat started hard , but it started and idled . Now it runs great , plains off fast , very responsive to throttle adjustments and max rpm its around 5400 , but now it starts hard I have to play with throttle or choke to get it going . any ideas ?? thank you , I just want to add the bottom carb was very dirty and jets clogged
