Stratosfied
Ensign
Thread starter- Joined
- Mar 14, 2003
- 915
The Primer bulb on this unit stays very hard all the time. Even when the rig has not been run for several weeks. I have just replaced the bulb on the Oil line and also the Gas line along with the fuel filter. Is it normal for this bulb to stay so hard you can't even squeeze it? I have tried to open the oil cap up on the rig when its at home to see if that would help. I also have noticed some oil coming from the covers on the carburator and collecting in the bottom of the engine area. I keep the OB trimmed up on the motor toter when not in use. Any Suggestions would be appreciated. Also the warning siren comes on when I turn the key to on. It is the continous signal even when the motor is not running. Thanks For the Help
