1995 Johnson 50 hp no spark
GP3998
Model J50TLEOD. Battery was starting to get a little low, put on charger for the day, should be able to check again about 5 this eve. Thank you
oldboat1
Try with the yellow rectifier or rectifier/regulator wires disconnected. If spark, replace the rectifier/regulator.
GP3998
No spark with rectifier disconnected. I am doing all my test with a remote starter button connected to starter relay is this a mistake?
jakedaawg
That's not the proper time base voltage.
I dont use a dva, I use a peak reading voltmeter but I think they are the same.
GP3998
Performed test again and come up with power pack faulty.
white/blue connect 86v, white/green connected 72v
disconnected readings are .6 and 1.18. Ohms readings for power pack; orange/blue to blue 70 ohms, orange/green to green 70 ohms, brown & brown/yellow are 10m ohms
GP3998
Will have part today, will install this evening and let you know. Thanks again
Honorary Supreme Mariner
Perhaps look at post # 2 again.----Nothing else has worked / given you a happy ending.
GP3998
Got looking at motor again and stator output yest fails with only 200 volts. Looked at when I ordered part and ot was a 4amp instead of a 12amp. Are 4amp ignitions lower voltage? Did I find the problem? Thank you
The 4 / 12 amp refers to the BATTERY charging part of the stator and NOT ignition..----Perhaps 4 amperes at idle and 12 amperes to charge the battery at full throttle.------Keep trouble shooting on this motor !!
oldboat1
should be a 20amp fuse in the system. worth checking. "died like you shut the key off" sounds like a blown fuse.
Doubt a blown fuse is the problem.-----That motor can be started with a dead battery when pulled over with a rope.------Fuse is for the cranking / starting bits of the motor.
