1995 johnson 48 problems
Navygus
I've recently acquired a 95 bass boat with a 48 johnson on it.
Boat has been sitting past couple of years hasn't been ran.
The carbs had been rebuilt during this time period. Any ways
Boat cranks fine water pump working great stream out tell tale
Boat idles good goes into gear but wants to die when opened up
Full throttle. Havnt started checking parts yet wanted to ask before
I do since it could be simple as a fouled plug or something major
batman99
Do compression test and compare their variance as well. Must be within 10% variance across all pistons
Install new gas. Double check pre-mix ratio as well.
Check all gas lines / joints for leaks. If needed, replace with new lines and new squeeze bulb.
Install water separation / filter unit. for example: http://www.boatingmag.com/how-to/installing-fuel-water-separator
Carb cleaning / carb kit may be needed. Ethanol mix gas loves plugging up carbs with gunk.
Check fuel pump "volume". Especially at WOT. If needed, replace pump (or install new kit).
Hope these ideas help.
Navygus
Thanks sounds like what I was thinking gas in the tank smells
Pretty bad looks like the mix may be overly rich also. Ethanol had
Came to mind as well I know it wreaks havoc on my chainsaws
I'll start there check that first. Thanks again
Navygus
thanks for the help I checked compression it was good checked fire it was all good but the boat still didn't want to run so I dug into the carbs guy had actually had them rebuilt to bad they never drained the gas out prior to parking it for three years. I spent about 3 hours cleaning scrubbing them out. top carb looked like a mixture of tar and karo syrup bottom wasn't much better but actually had fresh gas in it. put it back together boat runs like new now.
