1995 Johnson 40 hp
Rick.
Hello all. I want to pressure test the above motor gear case. I noticed a tiny bit of milky oil when l resently was getting it ready for winter storage. I drained it completely and found the initial drainage was contaminated but only a very little. The rest of the oil (probably 95%) looked normal. I want to do a pressure/vacuum test but my manual doesn't say anything about it. Would anyone know the correct numbers I should pump it up/down to? Also I'd like to hear comments as to why such a small amount of the oil was contaminated. The motor had not been used in the previous two weeks but I thought once it was contaminated it would make all the oil milky.
Thanks, Rick.
Honorary Supreme Mariner
I consider those gearcases to be less than robust.-----Tear it apart.----Inspect gears.---Replace pinion bearing.------Install a seal kit.-------Pressure test at 5 to 10 PSI.
Crosbyman
10-15 lbs either way (pressure and vacum will show up leaks )
it coud have been just bad / reused nylon washers on the oil plugs
give it a try with new washers and proper torque and if the water does get in well you know you ahave a reseal job to do. look for mono filament pieces on the prop shaft...:-(
I purchased the red pump shown ... works ok
Got the screw adapter for the gearcase from those oiler pump kits used to refill the gearcase.
If seals have 25 seasons on them, then put a seal kit in.
