Thanks ahead of time for a response, as it will be greatly appreciated. I have a 1995 30HP Johnson. After sitting this past winter I went to start it up and the motor is turning over extremely slow. I tested the battery, it was bad, so I put installed a new one. I'm getting 12.5+ volts between the terminals, so I know it is fully charged. When cranking i'm getting 9.5-10 at the starter. I've cleaned both cable ends that attach to the terminals, but not sure what else to do. I know the battery is charged but all it seems to do is turn over very slowly 3-4 times. However, every now and then it starts as it should, but not often...
Any ideas/suggestions? Please advise!
Paul
Paul
