Hi guys and gals, fresh newbie here but I've searched your website many times but now I've finally ran into a problem I cant find an answer for. I just bought a new 14' double wide mod V hull and everything seems to be good except I went to change the lower unit oil today and saw it was a little milky. So I bought 2 things of marine lube and flushed with the first bit and filled it back up with the second before darwin slapped me in the face
so I wasted a bit of lube. But anyway, I was running the engine to test and read the new spark plugs when I noticed a grey slurry coming out behind the prop. I took the prop off thinking that it would be the prop seals, but I dont think thats it. It seems to be leaking from up front. I took some pics so maybe you guys can help me out.
1995 Johnson 25 HP 2 cycle model J25EEOA
Thank you for your help!
