1995 Johnson 25 thermostat questionw
mkhatcher
Hi, I've been tinkering on this engine for a bit and finally got the engine running decent. I cleaned and rebuilt the carb and fuel pump and she runs fine. Question is, after running for only about 15 seconds from cold, warm water starts to flow out of the exhaust ports on the back of the midsection. I've read it should take about 2 minutes of running for this to happen but that could be wrong. Anyways, I just wanted to know your opinions :) Thank you
boobie
Is the motor overheating ?? Have you checked the water pump and the thermostat ??
