1995 Johnson 115
Jdl1123
I have 115 johnson and will not start on neutral but once you press the neutral button n put it in gear it start right up then you let go of the throttle it does off what can this be last week it was running great
jakedaawg
Sounds like the switch in the controller is kattywompus. Take apart and inspect. Use common sense, if you need to force something apart or back together your doing it wrong...
the switch I refer to is the one with yel/red wires going to it.
Jdl1123
I took it apart yesterday and everything look ok I thought it might be the neutral control switch
jakedaawg
When you say it will not start in neutral do you mean the starter motor does not spin the engine over or it turns it over but motor will not run?
Jdl1123
The engine turns over but will not start in neutral only when its put in gear
