1995 J50DTLEOS Wiring diagram
Forseti
I am in search if a wiring diagram for a 1995 50 HP 3 Cylinder outboard. The book I had bought doesn't have the correct one. Can any of you send me the page if you have to correct one? Also ... My fuel pump has died .. its a VRO but I premix my fuel... is there a cheaper "regular" fuel pump I can replace the VRO with ?
ezeke
Re: 1995 J50DTLEOS Wiring diagram
You can use a conventional lift pump to replace the VRO system if you pre-mix. The superseding pump is OE # 0438557.
You can find the applicable fuel pump diagram on the 48HP models for 1995 here: http://evinrude.cust.shopatron.com/
