1995 force serial number
Jiggz
Usually, this is a decal or sticker on the transom clamps. However, being more than 25 years old, it's most likely faded or probably even gone. If you need this info to buy parts, you can at least find out what model of engine you have and will most likely get the correct parts.
Antonio-88
I needed it for title purpose
Jiggz
If the decal is totally gone, there's very little option left except to re-traced the original title based on the serial number of the boat. And usually, the boat's serial number is stamped on the transom. Now if the motor is an upgrade or downgrade or not the original, then most likely you are out of luck.
jerryjerry05
Original motor with the boat???
​Send hull# to the manufacturer and they have the records on what was sold??
Antonio-88
Thanks everyone lucky me Texas parks and wildlife were able to track it down with the serial number of the boat thanks again
