ddixon1000
Thread starter- Joined
- Mar 25, 2009
- 2
Hey all,
I am a newer boat owner (1 season) and have a 1995 Bayliner with a Force 120hp that has been running great. I decided to try winterization on my own but think I may have done some things wrong. Heres what I did.
1. Flushed the engine on muffs for 5 minutes.
2. Added Merc fuel stabilizer as the Boat rep told me Seafoam and Stabil are now considered horrible for two strokes due to their alcohol content. He said they cause condensation instead of prevent it.
3. Ran the stablilizer through for 5-10 minutes.
3. Disconnected the fuel line (is this wrong) and let run while fogging the carbs(engine smoked) and let the engine die.
4. Unscrewed the screw from the bottom of the carb bowls and let the gas drain.
5. Removed plugs andSprayed fogging oil into holes and turned the motor over a few times.
5. Replaced the lower unit oil no signs of water
6. Took off prop checked for fishing line (none) greased spline.
The two things I think I may have done wrong was disconnecting the fuel line and I noticed the plugs had a black residue on all four. Is this bad? Also the plugs didn't look like regular plugs they had a flat end not the standard spark plug end.
