1995 force 90hp 2 stroke timing is at idle
Keith201
I have a 1995 force 90hp 2stroke does anybody know what the degree timing is at idle???
jimmbo
There is no Timing Spec at Idle. There is a Max Advance Spec, and a Pickup Timing spec(that is where the carb(s) is about to open from its fully closed position. Retardation of the Spark is what sets the Idle Speed, and that setting can change when a Higher or Loww Pitch prop is installed
jerryjerry05
Read the first 4 -5 posts at the top of the Force forum.
Lots of good info there.
Google timing Force outboard and Utube videos have what you need too.
