1995 force 70hp Install, Steering Rod Issue
atengnr
Hi, had hoped to finish install of this new to me motor over weekend, but couldnt install steering rod, as it hangs up about 2 inches in. I pulled motor onto engine hoist to install. After cleaning tube, regreasing both tube and rod, still no luck. I noticed that the tip of rod where bolt hole is, is bent slightly (boat is new to me). I presume isnt supposed to be?
Thanks alot.
atengnr
Also, could someone point out where the negative cable should mount (on powerhead)? Thanks
roscoe
yes steering rod should be straight.
Perhaps you can get it through the tube if you fully extend the rod from the cable.
If I remember right, there is a bolt into the block, just below and slightly behind the starter.
Look for a bolt that is probably only finger tight.
jerryjerry05
You said:
I noticed that the tip of rod where bolt hole is, is bent slightly:
It has to be straight.
Someone might have hit the end of the rod, mushrooming the end?
If it can't be straightened? Then replace.
It will do nothing but cause trouble forever.
On the cable is an engraving. It has the size, sometimes in feet, sometimes in inches.
atengnr
Thanks new cable arrived. Appreciate the help.
atengnr
Thanks all. Another issue found, i am missing the cable conmectors in the control box. Anyone know where I can get these? Thanks
