1995 fling won't go neutral with gas forward
richyman
someone said a cam won't fall into place. runs great once started however when you push lever and move throttle forward in wont fire. sometimes i pull throttle back and not releasing button to start. any help??
njlarry
Re: 1995 fling won't go neutral with gas forward
have you checked the shift cable cover for corrosion by the reverse gate on the drive output?
