1995 excel 3.0 l mercruiser questions
JOHNNYPLATA
firstly this site is awsome! ive tried searching through the faq but couldnt find what i needed. 1. just gettin ready to buy this boat from a friend, got it started but it has a constant beep which i learned from you guys was a over heating issue but it goes off before its even started...it reaches over 200 degrees. im a total newbie my last boat is a 76 sears tri hull with a 5hp......... and a canoe please help.
fat fanny
Re: 1995 excel 3.0 l mercruiser questions
If your buting this rig I would ask how long has it done this? and if you do buy it the 1st thing is to try all the most inexspensive troubleshooting 1st test thermostat or buy a new one, test and or replace the temp sending unit, run it on muffs and make sure your getting water to the circulating pump, if not pull lower leg and rebuild the impellar with the complete kit, re-check to make sure that your getting water to the circulating pump, after that do a compression test on all cylinders should be @ or prefferably above 130psi and then if all above is good take it for a sea trial. If @ that point you are satisfiied with the rigs performance it's your choice @ that point perform a complete tune up and get a merc service manual and read it cover to cover. Good luck!!!!!!!
JOHNNYPLATA
THANK YOU i am going to pull the lower unit and replace the impeller ( hopefully its not too crazy of a job) a friend says they should have them at my local bass pro shop. id like to get it in the water before seasons up as im paying for it in feb (thats when my friend is buying a new one).
dubs283
beep on key-up is normal - it lets the operator know the warning system is operational
oil pressure and temp are the two main causes for warning tones, if this is efi then there are more failures that will give warnign tones
sounds like you got the problem figured out - overheat
replace the impeller/water pump assy (don't know what you are working on) but if the pump is in the drive it is either a mercruiser or OMC cobra
don't mess with the t-stat unless the impeller/pump doesn't solve your overheat issues
