1995 Evinrude pt&t console model 3 Cylinder Running Problems
rauzers
Hello all, i'm a newbie to this forum, and looking forward to resolving ignition issues with my 35 hp triple.
I am on my third power pack and becoming a little frustrated.
The original bad one was replaced 5 years ago with the new improved version. When I put the boat away, the engine was running perfectly. The engine has been sitting outside under a tarp for the past two years
I'll start with the present and work back.
The current pack is part #586472 L, which I purchased a few weeks ago from a person who said it was not his issue and wanted to resell it.
I installed it, and the motor started, ran perfectly for 5 minutes, then cut out. I turned it over and there was no spark. I let the engine cool off for 10 minutes and it started instantly, but died after 3 minutes. Tried it again after another ten. It sputtered, died and no spark. There has been no spark since.
The boat sat for a week, and I tried to start it. No spark. Went through the rectifier disconnect exercise. did the kill switch exercise, tested output from the stator, which was huge.Finally took off the pack again, and took ohm readings which seemed to be in order in that they were constant from different points to the wires leading to the coils. reinstalled the pack, made sure the battery was fully charged,and yes, the engine started and did exactly the same thing as previously, dying with no spark, and then the spark disappearing again.
The lack of spark seems to be associated with the engine or some component overheating, yet the engine does not feel hot to the touch and the overheat horn does not sound. I tried disconnecting the sensors I could find and no change.
So, sometimes no spark, then sometimes great spark. I have checked all the grounds. The engine just slows down and dies.
I cannot figure why there is spark sometimes and sometimes no.
Any ideas? I'm running out of them.:confused:
boobie
Sounds to me like another bad pack seeing it was a used one. Buy a new one so you have some warranty.
jakedaawg
I would start by making sure that someone did not tap into the blk/yel wire to use as a ground for some piece of electronics.
Then, I would preform resistance and DVA checks of all components while the engine is warm and wont work. It is possible that it has something else knocking the pack out. CDI website has a troub;le shooting guide if you do not have the manual.
rauzers
Thanks jakedaawg.
That makes a lot of sense.
Weird part is no one has worked on it before.
Right now I can't get it to fire. No idea why.
I've followed the cdi troubleshooting and can't find anything untoward.
All signs point to the power pack. At $500 a pop, gets a little expensive. I'm going to take readings on the two packs and see what comes out.
Also, I'm going to blow compressed air on the pack and see what happens.
What I'm not getting is the heat influence
Thanks for the input
rauzers
BTW, I've been rebuilding and repairing OMC (lawn boy, vintage outboards} stuff up until the last 10 years. Never come across something like this
jakedaawg
Please post a model #. You shoould be able to find it on the engine clamp or on a welsh plug at the top of the block.
