1995 evinrude 9.9 2 stroke bogs on load. Idles nice and revs wot nice when not in gear. Runs the same way in a bucket in gear. Now put in gear in a lake and its idles great but at about 1/3 throttle that about it on a load. Doesn't matter how much more throttle you give it just doesn't goes any faster. Will not put boat on plane. Carb has been cleaned and has good spark. Been sitting for about 7 years because of this problem. Cleaned carb back then but didn't help any. Use to work great until this problem now just getting back to messing with it again. Prop was changed back then and didn't help. No weight has changed on the boat. Took it out today probably does about 3mph. No prop slippage or any surging. By the way I'm not a boat motor person. But man this thing runs and revs right up out of gear or in gear not put on load. Compression tested 100psi on both cylinders.
