parker1700
- Aug 7, 2006
- 18
Put the boat on the water and made a three mile run to fishing spot. Engine ran great until I throttled back to come to a stop and engine shut down and would not re-start. Let set for about thirty minutes and tried it again and still would not start. Engine smelled like it was flooded so I removed plugs cleaned and replaced. After several attempts engine started but would only run a partial speed and no oil alarm sounded. This oil and gas is mixed at a 50:1 ratio and has the correct fuel/oil mix in tank. After squeezeing the primer bulb a few times I attemped to start engine but failed and had to be towed back to landing. After I got back home i was able to start engine.
Not sure what to check. Can some one help.
