1995 Evinrude 50HP electrical issue
Lisa27
1995 OB Evinrude 50HP trim-up doesn't work all of a sudden, but down does. The radio also went out at the same time, suddenly. Is it likely a fuse?
EGlideRider
Re: 1995 Evinrude 50HP electrical issue
A fuse may be the problem with the radio but not the trim.
The most like cause is a defective relay. There are two of them in the motor housing. Swap them to see if the up-trim works but not the down trim. And if one is bad, I recommend you just change both of them in a 95 motor.
Of course you may have a bad switch or a wiring issue but I would check/change the relays first.
Welcome to the forum. Please report back your findings.
