1995 Evinrude 40hp 2 stroke only idles
Retrevr
This motor sat for a few years, I have replaced the oil injection fuel pump with a standard one. The new fuel pump has one outlet hose which I connected to the fuel manifold that the old fuel pump was connected to. The engine runs and starts fine even cold, however today when I took it out it would only idle or maybe vbarely above. Any idea why? Thanks.
Texasmark
You are in the Black section my man. Go to the OMC forum and you will have better luck getting an answer.
