OK , here we go. Been out running the the engine and deciphering the warning horn on my boat vs the warning horn description in the OMC Evinrude manual.
The reason I am doing so is a bit of paranoia from past experience whether it was a VRO failure or not. At the end of last season the motor did not seem to be using as much oil from the reservoir as it had been. I let the engine sit for several months while I replumbed my bilge thru hulls, ran new wires and that fun stuff. . So now was time to start the engine . So running in the test barrel there did not seem to be much smoke and I did not distinctly smell the 2 stroke oil burning. I now think that I may ,I repeat may , have over reacted. I decided to run the VRO test but first needed to know that my alarms functioned as they should , or at lease functioned.
I explained that I have a harness adapter and that my alarms do not mimick the description in the manual. I was not even certain that each component, Hot, Low Oil, No oil and check engine sent a signal to the warning horn. After testing and retesting this is what I come up with. Each sensor I guess to call them does function. The issue that I will live with is this.
Remember I have the system check tachometer with a 1995 engine and adapter.
Hot = one long tone - system check Hot light comes on
Vaccum sensor switch = Hot light comes on tachometer and the tone is the same as Hot
Low Oil = Low oil light comes on tach . The tone is again the same as Hot
No Oil = Hot light comes on - The same tone as the others. This being a 30 second continuous .
So the fact is that I do have alarms, but they are all the same and really can not tell if there is a no oil , vacuum, or hot issue occurring.. I guess next time an alarm goes off I just stop til I figure it out. Pump the fuel bulb, pump the oil bulb and break out the infrared thermometer.
And yes sir the No Oil light and alarm take a surprising amount of time to go on. That is part of what threw me.You will certainly think the alarm does not work if running at an idle and waiting for it.
I will be running with premix 50:1 plus my resevoir and VRO until I am sure that the VRO is working.
Jake and Rusty your replies were right on. Thank you.
Any questions please ask, glad to answer.
