1995 Evinrude 130 No spark bottom cylinders
JeromeyS
So I pulled the boat out last night and tried to fire it up in the driveway. Eventually it tried to run, would not without giving it a lot of throttle. Put the temp gun on the cyl. heads and #1 was the hottest with the rest being quite a bit colder. I pulled the plugs and checked for spark, the bottom cylinders (2&4 I believe should be their designation, please correct if I am wrong) did not show any spark. I replaced 2 coil packs last year so I changed the signal wire coming from the power pack to the known good coils and there was still no spark. Can you guys lead me in the right direction? Thanks!
gm280
Sounds like you have a basic idea for troubleshooting your problem. And that IS good. First thing is to determine is IF the coils are all good. But you can't do multiple things at the same time. Meaning only work with one issue at a time so the results are true. If your top coil is firing, move a suspect coil to that location and see if that coil fires as well. If so swap in the next suspect coil to verify. Once you have all the good and not good coils separated, then move to what is feeding those coils and see if your good coil will fire in a non firing position. If not, then the ignition part that feeds that non firing coil is the next suspect. And follow that scenario until you located all the good and bad parts...
JeromeyS
Got a few resistance tests done this morning before the rain came:
Stator- charge (brn-brn/yel) 392 ohms
power (org-org/blk) 96 ohms
Trigger- all 41-42 ohms
I have seen differing values for the stator, can someone let me know what the values are to be?
JeromeyS
OK, got the DVA from CDI in the mail today. Here are the voltages:
Stator charge 250V
Stator power 21V
Trigger blue and purple have 6v
Trigger green and pink have 2v
Orange power pack wires:
blue and purple 150v
pink and green nil
Now, it appears the stator voltages ore ok but the resistance is on the low side. The trigger spec is .5v min., however the green and pink cylinders are the ones that are not firing. Is this voltage low? It appears to carry through the power pack where the output from it is almost nothing to the coils.
