FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
there are 2 seals plus the large o ring on the props housing and a oil seal on the upper.
is that all the seals that can cause oil leaks. does the water pump have any thing to cause this ?
There is an 0-ring seal on the shift rod.----2 seals and an 0-ring on propshaft bearing housing.----2 seals on the the driveshaft below the water pump.----Water pump does not cause oil leaks.-----Some oil leakage out the prop shaft / propeller area is normal for a 2 stroke.
Pull off the drained lower unit, and pressure it with a few lbs from a tire or foot pump (I use a basketball needle and a piece of rubber.) Use a spray bottle with some dishwater soap and water to locate leaks.
