1995 9.9 controls to a 25 hp
Chrism1367
Hi I have a 9.9 with remote electric ignition and controls that is dead, and saw a 25 hp 1995 with controls setup like mine, if I were to put the 25 hp on the boat would all of the controls from the 9.9 work on the 25? I've searched and cannot find a thing. The 9.9 is j10releoe
probably not. the 9.9 would have only needed 3 wires to run. kill switch and start the controls may look the same, however there are more circuits once you get out of the kicker motors
Chrism1367
Well I know the 9.9 has 2 wires to the primer, 2 to starter solenoid, 1 that goes to a 20 amp fuse, and one that goes to the ignition coil. There might be another, going to look at it later today. Does that sound like a complete setup?
Chrism1367
The 9.9 isn't setup like a kicker motor, it is on a small 14' pontoon boat as the main motor
flyingscott
Does your 9.9 have the red plug coming out of it? If it does make sure the 25 does and it should swap over. Or you will need the adaptor Make sure you have the correct brackets.
Chrism1367
I just googled that and no I don't have that big red connector coming out of the motor. All wires go from control box to battery and directly to motor, they are all just taped together then split in the motor to it's corresponding connections. I guess I'm gonna have to go look at the new motor. Do they make an adapter for those?
flyingscott
Sounds like somebody rigged it up. Put a pic up of the wiring all of it and the control box.
Chrism1367
No Title
This is an image off the internet but is just like my control box
Chrism1367
Ok well I'm trying to upload but pics are too big, I just found a bunch of bundled up wires hidden underneath the boat, I'm gonna have to check there.
Chrism1367
No Title
This is underneath the floor
Chrism1367
No Title
This is the side where the wire harness goes into and connects to everything. Don't know if that helps
Chrism1367
No Title
Ok well I think I found it....does that look like it?
flyingscott
That is it If the 25 hp has that plug you are good to go
