1995 88 SPL Temp Sensors.
Strigidaeo
I need to replace the temp sensors in my Evinrude 88 SPL due to the insulation cracking and breaking off with bare wire exposed...unless someone has a better idea. I have a Johnson/Evinrude 88 thru 115 Service Manual but it's a little vague when it comes to this subject. I have one sensor in each cylinder head and visually it's removal doesn't seem very intuitive...or am I missing something.
interalian
If it's a crossflow, hey're held down by the figure-eight shaped head water cover. You need to remove that whole plate (and replace the gasket). Beware of frozen bolts.
interalian
You could post your model number or a picture of the cylinder head. Here's a picture. The figure-eight plate is held down by 16 bolts.
emdsapmgr
The 88 models were all crossflow models. The cyl head cover is the flat plate that goes around both spark plugs. Once you pull that off, the overheat switch can be removed from the backside. You will need to replace the head cover gaskets, too.
James R
Little tip on removing the sensors once the plate is off. Shoot with WD40 and push a very small screw driver down between the side of the rubber and the aluminum cavity. Do this in several places then carefully pry the sensor out. I tend to have good luck with using an impact wrench to remove the cover bolts. The lower ones you just have to use a socket. They do shear off very easily. When you put them back clean up the threads with a tap and die and apply OMC sealant to both sides of the new gaskets and to the bolts right up the shanks.
Strigidaeo
Thank you all! Is there a torque sequence chart available for the re-install?
interalian
Start in the middle and work in expanding circles. Torque to half for the first round, then full torque on the second. I don't have the spec handy.
