Re: 1995 60 hp evinrude
Well its been a couple of months now
what was the outcome of the noise ?
are you sure its not the very top of the engine making the noise ?
I ask this as after just taking the flywheel off my 1995 60hp tripe, i found the stator was very loose !!!!
Now when thinking about it, i also had a situation once when i heard a strange noise from top of the engine
and it also died.
Then started back up no problem and no noise afterwards.
Now when i just found the loose stator it all makes sense, the stator could of made the noise i heard.
It also made a strange noise from the very top when in slow mode due to faulty temp switch.
On a friends 50hp twin his stator makes a terrible racket, that is also loose, but that engine is
never going back on any boat due to other problems.
I would definitely check for a loose stator, and do a compression check straight away.
Do not try running it untill you find whats wrong or you might just kill then engine completely.
phill
