1995 50 hp Johnson vro
79h20s
I have 95 Johnson 50 that acts like its running rich and loading up , I have cleaned the carbs, check spark and compression is 120 on both cylinder's. Runs rough at idle and boggs a wot for 15, 20 seconds then clears up and run wide open
fireman57
You might have a float sticking and when it works right it clears and runs. When it bogs hit the primer solenoid and see if it picks up. It could be starving for fuel instead of loading up.
jakedaawg
Clean the carbs. You dont need a kit. Just take apart and blow carb cleaner through all the passages. Adjust mixture on top carb first then bottom carb and you are good to go.
79h20s
Carbs were cleaned , tried the primer and it stalls so it's definitely rich
fireman57
He said that he cleaned the carbs in his post. I would suggest that he remove the jets and make sure they are clean. Run a wire through the holes and make sure they are clean.
79h20s
what is a good starting point for the low speed idle screw?
fireman57
You can do a search on here for carb settings and you should find several threads. Best is to buy an OEM manual from kencook.com. Clymer and Haynes aren't very good.
