1995 5.7 mercruiser bellows
Johnson110
Hi, Just had the outdrive put on a few weeks ago. Today I look under and see a bellows ( lower one ) is ripped of the clamp closer to housing, question do I have to pull the outdrive to get at the clamps or can this be done with the outdrive attached to the boat?
Re: 1995 5.7 mercruiser bellows
Ayuh,... The bottom bellows is the exhaust,... It's Much Easier to fix with the drive Off...
Johnson110
Thanks, I just paid a guy to put the outdrive on, Are there and SPECIAL tools involved in changing the bellows, I got the old one out! Please help!
Johnson110
Can the exhaust bellows be installed with the outdrive on the boat, also is this a critical part with regards to leaking water into the boat! Thanks for any replys!
Nope,+ Nope.....
Have you looked at the Manuals up in the Adults Only section yet,..?? You Should....
Johnson110
Thanks, My computer was down for couple of days, thanks to cablevision!!! anyhow I just ahd a guy changs the bellows 114.00 dollars, I like that bellows that attaches to the transom end only, if I had access to the site, that"s the way I would have went!
