1995 45hp. Johnson (J45RCLEOD) performance prob
oldcanuck
I have a recently purchased 45hp electric start model with uncertain history. It starts well and has new plugs, but runs a little rough at slow speed, runs well at mid-range and misfires or hesitates at full tilt. It likely uses the usual Johnson 0584528 power pack, but is the problem in the carbs or elsewhere? This engine may have sat around underused for some years, but looks clean under the cowl. I was considering a fuel system cleaner, however, an auto mechanic said it was a waste of money. Does anyone have a suggestion?
Honorary Supreme Mariner
Start with a compression test.--Then check for very strong spark on each lead.----Perhaps run with a timing light to monitor spark on each lead.---If you get steady spark at all times on the timing light then the problem may be elsewhere.
oldcanuck
Your assistance is much appreciated. I will try your suggestions.
