Re: 1995 4.3 bad compression test
I would first like to thank everyone for their help and advise. Although I am new to boating, I have had some experience with small block Chevy's in 4x4's.
I do have a couple of questions. After reading the shop manual for engines removal, there does not seem to be any bolted connection to the transom or out drive. You just unbolt the 4 engine mounts and pull the engine. I have already removed the out drive. Is this correct?
My other question has to do with the cause of the problem I have with #3 cylinder. If everyone agrees that the piston erosion was caused by detonation, why only #3 cylinder? Some of my observations are 1st: #3 had a different spark plug than the others, which I believe was a colder plug (the porcelain part of the plug was more recessed into the threaded part of the plug, exposing less porcelain into the combustion chamber). This I believe would lessen the chance of detonation. My 2nd observation is the heads and block where remarkably clean, no sludge build-up in lifter valley or under valve covers. Also, no rust build-up was observed in any of the water cooling ports of the heads and block. The only rust build-up I saw was in the thermostat housing and exhaust manifolds/risers. Could my problem be caused by overheating? When I repair this engine, I do not want the same thing to happen again.
Any and all advise would be greatly appreciated.
