Motoman614
Thread starter- Joined
- Sep 12, 2007
- 10
Last weekend my engine overheated because of a bad impeller so I thought I would check the compression before I do anything else. The results were 140-150-180-75. What do you guys think may be the problem most likely. Could I get lucky enough to have it only be the head gasket. If it needs a complete overhaul is it best to look for a long block somewhere or I would be open to any other options you could bring to my attention. Thanks for any advice in advance. I am guessing the compression should be 180 all the way across.
Jamie
Jamie
