1995 250 V8 looper lower unit
MFAST
Does anyone know if a V6 lower will fit on a 1995 250 V8 looper?
MFAST
Thank you for the information. I have found another v8, a 1986 275hp Evinrude that is very clean. I need this motor for a heavy cc fishing boat 22 feet long. If I run a holley blue pump with premix straight from tank to motor and make sure its turning at least 6k wot, is there any other recommendations you have as far as setting this beast up?
Faztbullet
You have to be very careful with this model especially if it a counter rotation .The reason is this motor runs BACKWARDS and uses a different flywheel,stator and gear set. You can convert t to CW rotation but you would have to change the mentioned parts .Also the lower unit will not interchange with your existing motor due to crankshaft length between years, and don't expect a performance increase as the 275 is right at 250hp at prop like your 1995 one
