1995 225 JOHNSON OUTBOARD
TJWA1
Hey everybody, I found a clean used 95 225 ob, and need to know if there is anything I should know about this motor before purchasing it. For example, any major problems or plugs fouling etc. From doing some reserch I have found that Johnson redesigned their motors in 96. Please inform me if this is true or not, and what were the major changes.
Fitch
Re: 1995 225 JOHNSON OUTBOARD
What is the price you are paying?
MERCMAN
THE MAIN THING ON THESE MOTORS ARE THEY HAD A BAD PROBLEM WITH THE PISTON RING SET PIN WORKING IT'S WAY OUT AND TRASHING THE SLEEVE ON #2 CYLINDER. IT STARTED IN 1994 AND I HAVE IT ALL THE WAY UP TO 1998 MODELS. YOU NEED TO CHECK COMPRESSION AND LOOK INSIDE THE CYLINDERS WITH A BENDALIGHT LOOKING AT #2 CLOSELY AT ABOUT 9 TO 10 OCLOCK NEAR THE INTAKE PORTS FOR GROOVE UP AND DOWN CYLINDER WALL JUST THOUGHT I'D LET YOU KNOWN
