Now we are getting somewhere. Leave it at 4 atdc, get it in the water as Fazt says, adjust mixture screws as lean as possible (in makes it lean, out makes it rich), and adj the timing to get it to about 750 in gear in the water.....
Just a warning...it may not play right. You might have to fudge to get it right for your particular motor. They all don't behave exactly like the book says.
If you get it too lean, it might start lean sneezing. Just open the screws up 1/2 turn...all of them equally....and re-assess. It will take you a while, so plan to have enough time to get it right. If you get it too rich, it will likely drip unburned fuel on the driveway when you get home.
If everything is like it should be, timing should be right at 4 ATDC, and the idle screws should be at or around 6 turns out...maybe 5-1/2.
Remember, you never use the linkages to "prop the carb butterflies open" to get the right idle. All butterflies must be closed for proper idle.
