1995 2.5 blackmax 200 offshore catbureated
Drogers91
I have a black max 200 on a 25 ft sunesta Deck boat Whenever i adjust the trim while running high rpm the rpms will drop Some sort of electrical issue. Anyone have similar problems? And know a fix or what is causing it. another problem that has come about when i go to get on a plainsomtimes the motor wont run over 3000 rpm when im holding it at full throttle new to this motor so anything helps
